Hi
I am working down the list of "minor" defects on my Stag and have come across a "catch 22" type problem.
The drivers seat adjustment is jammed. The seat is stuck at a reasonable position for me to drive but the car is actually my wifes and she is looking forward to driving it in the spring. Also I believe it is a MOT requirement that the back/forth adjustment works? (Can only assume that last July the PO's MOT tester was of similar build to me. The 2 testers at my classic freindly local garage are respectively 5'6 and 6'3!)
Searching on here and reading the manual it appears this mechanism can only be accessed by removing the seat but to do this one has to move the seat back and forth to gain access to the mounting bolts.
But as the seat is jammed I can't do this.
Is it possible to remove the squab to gain access to the mechanism from above in situ?
