I removed the near side block drain plug today, which was as I had expected. But the off side one appears different. It is more like a bolt. Is this it or something else? I did try and gently remove it and it was solid, so I would like to be sure before I get serious with it.
Is this the Drain plug
Yes I have already removed the other one, but it was a completely different design. It was as expected with a washer, not like this one on the off side which sticks out like a bolt and is horizontal. It also looks like it may never have been removed, unlike the other side. Just though it was very strange to be a different design from one side to the other.
Smaller part is a bolt in my engine too!Originally posted by Nigel W View PostInteresting. The hexagonal bit is presumably what screws into the block, but what is the smaller part sticking out? The one I took out from the other side is a plug as per the Rimmers Catalogue for a late engine (76).
There were drain plugs and drain taps. The bolt-in-a-bolt looks like the original was a drain tap and the wings of the tap broke off, so a bolt was used to replace the original tap, using the original threaded drain tap housing.Originally posted by Nigel W View PostInteresting. The hexagonal bit is presumably what screws into the block, but what is the smaller part sticking out? The one I took out from the other side is a plug as per the Rimmers Catalogue for a late engine (76).
DrewThe answer isn't 42, it's 1/137
I have now removed the long bolt used as a drain plug, and the threads, both male and female look OK. However, when I went to the Rimmers catalogue it only shows the near side plug and the rear one (both are 129077) there is no mention of the off side plug. I rang them and they looked in the factory manual and confirmed that it only showed the nearside and the rear. Does anybody have any ideas whats going on? Its a late Mk2. Should I put the long bolt back in or order a drain plug and if so do you use the fire washer, or is that just for the earlier taps? confused of Hereforddrain plugs.JPG
