Gear change Auto
    Gear change Auto
    Hi all
    just got my stag up and running after buying it 3 weeks ago
    its an auto.
    The thing is when I put her into gear there is a big clunk and she's in gear
    Is this normal
    Kyri
    Hi Kyri,
    It's normal, it even mentioned something about it in the original handbook. Just check the gearbox oil as per the instructions, there are a couple of methods for doing this,on here, just search the posts,,also makes good bedtime reading.
    note-Some of the more well off owners have put 'zf' gearboxes in their Stags,,I'm not jealous really,,just saving up should mine go altogether, ha ha.
    Ken.
      Tickover a tad high can do this, plus if there is a lot of wear/backlash in the drivetrain it will sound worse. But usual culprit is too high a tickover speed.
        Originally posted by stagmyson View Post
        Hi all
        its an auto.
        Is this normal
        Kyri
        It shouldn't be that much of a clunk, what is the idle speed when fully warmed up, ideally you should have 750-800 rpm.
          Thanks for he reply's
          revs about 1000
          linkage a bit sticky need to sort out
            Agree that it is the tick over too high, but really for a smooth engagement with the BW35 box you need the tick over as low as possible. Mine is around 550 to 600 rpm.At that speed there isn't much of a clonk.
              ive got a bmw zf 4hp box
              who does the the conversion
              cheers
                They use a Jaguar ZF box. Tate and Lewis and Monarch (who sell T&L).
                Jeff.
                  As been said if the tick over is too high obviously you will never get gentle gear selection. I find 600 rpm tick over spot on with no jolt or bump. Having said that there is nothing wrong with a good jolt or bump
                    Your memory must be better than I gave you credit for Graham...
                      cheers
                      will need to drop the idle to around 600 and see how it goes
                        So you haven't found the camera that Stevie planted then.
