Hi another newbie question
Did a bit a work on the cooling system at the weekend consisting of the following
flush and back flush and flush again
new hoses and 82 deg thermostat ( correct for the engine number)
refilled with 50/50 antifreeze.
As far as I can tell its a standard Mk2 TV8 with viscous fan and original cooling setup.
My question is from a cold start how long does it normally take the engine to get to normal operating temp at idle
I left the car running to check for leaks -all ok but, it took only a couple of minutes for the temp gauge to sit at half way.
An infrared thermometer measured 75 deg at the top and 65 deg at the bottom( although its not a calibrated instrument)
Is this normal or have I missed something
My other car (herald 1360 ) take a lot longer to warm when idling.
