Worn cam bucket
    Worn cam bucket
    My previous engine noise now solved, was due to a badly worn cam bucket - can you spot the difference ?
    Which one is the replacement
      Ah I saw faversham classics out this up on facebook
        [ATTACH=CONFIG]32725[/ATTACH]
        What was the noise like?
          Hi Darren, it was a noticeable rhythmic metallic tapping from the rear of the driver's side cylinder head, consistent with engine speed. IIRC this bucket was from cylinder 6 and the adjacent bucket was also worn but much less (all others were fine).
          Yep, I picked her up from Faversham yesterday - and had a great drive back as far as Barton Mills before my VC failed (hopefully), now recovered to Norwich and new VC ordered
            Yep, I picked her up from Faversham yesterday - and had a great drive back as far as Barton Mills before my VC failed (hopefully), now recovered to Norwich and new VC ordered.
              Is the cam bucket also known as a pallet? I have a single clacking/tapping noise on mine which is slightly irritating. I presume these can be replaced with the head left in place?
              Trouble is I can't locate the noise, sometimes it seems to come from the top left hand bank, then it might appear to come from the other side. Sometimes from the front middle.
              I know it is not the timing chain. Someone has suggested it may be a valve guide.
              If it is a cam bucket/pallet, how expensive a job is it to get it sorted at a garage?
                ive had this for the last 2 years must get round to sorting it out next winter
                  The cam buckets can be replaced with the heads in situ but the cam needs to come out.
                  Apparently with such a badly worn bucket I was lucky that it hadn't shattered, risking more serious consequences. With the replacement 2 buckets and bit of labour not coming to much, it's personally not something that I'd want to leave too long before sorting. I had a full service anyway but would assume if the buckets were done in isolation then there'd be an oil & filter change to add on and maybe some re-timing work too.
                  Apparently due to some law of physics the loose buckets don't wear the softer alloy head !
                  (I'm not sure but thought pallets might refer to shims not cam buckets)
