Hello all, following my engine rebuild I am experiencing a very strange fault. It only occurs on a long journey where the speed is above about 60. Keep the speed down below 50 and I can drive around all day.
The issue is that when driving along, the engine/transmission suddenly starts to tighten up. (Feels like someone has pressed the brake pedal for you, hard as well) Upon feeling this, I dipped the clutch. As soon as I dipped the clutch the car will free wheel no problem but the engine stalls immediately.
Around the point of dipping the clutch there is a chaffing/grinding noise.
It has done this three times now, every time it does it I can get out of the car with my 15/16" spanner and turn the crankshaft perfectly smoothly and freely.
Get back in start it up and drive off. The engine runs sweet as a nut, no knocks rattles, pulls like a train, drives very well, the clutch is smooth, pedal feels nice etc.
The crank was reground mains and big ends, but thrust is standard, end float was tight - but within the specified range
The fact that the engine stops with the clutch pressed suggests to me that the issue is something forward of the clutch.
I've been pondering, clutch flywheels assembly or tightening up on the thrusts? The sound doesn't strike me as being an internal engine sound though, and it is quite loud, and a dry sound.
I think I am going to pull the gearbox out this weekend and have a look, but if anyone has and suggestions to fire about it would be interesting.
James
James
