I'm looking for someone who has practical experience repairing Stag floor/cills. I have found rust where the floor pan meets the inner cill. Problem is that I can't work out how these were originally joined. Does anyone know if the factory spot-welded the edge of the floor to the lower flat side of the inner cill, and then spotted on the outercill? This seems likely as I can't see any remains of a lip on the floor (as would be needed if it was spotted to the doubled flange of the inner & outer cills - so making this flange three layers thick). How are "new" floors supplied, with a flange, or just a plain flat edge? What is the usual method of repair if most of the cill is sound, so not needing to split inner from outer?
Stag Floor Pan
Guest
Hi, floor panels come with a flange, just had mine replaced along with outer sills, weld the floor to the inner sill.
I'm still struggling to get my head round how the floor pan, inner and outer sill all come together.
Does anyone have good pictures or diagrams of this area ?
Dave - as you say weld the front floor pan to the under side of the sill, does that mean you had flor pan sections without a lip
All advice greatfully received
JulianLast edited by jleyton; 4 April 2015, 09:18.
