B-post top caps
    B-post top caps
    Quick question, are there two types of B-post top caps,ive removed the two screws the cap lifts but wont come out
    thanks dave
    hi Dave, yes there are two types mate sounds like you have the full cover, undo the T-bar bolt and it will come out.
    Joel.
      Joel
      thanks,may have to bite the bullet then, didn't want to undo the T-bar as i have the sill off,also the carpet sill trim is different from my brothers anyway
      thanks dave
        Well you learn something every day.
          edd
          on this car i seam to have a mix of mk1 and mk2 parts,mostly mk1
            There are ??? whats the differences
              basically just cut in half.
              joel
                Ta, I've only ever seen the 1/2 ones.
                  I have the small ones but had to loosen the T bar to free them.
                    +1
                    Gerd
                    1976 TV8 Manual O/D in pimento red
                    1986 BMW R80RT
                      That's good to know. I was trying to lift one of mine to get a new door seal under it and although I loosened the self-tappers, it wouldn't lift. Now I know why!!
                        + another one. As the nylon electrical contact mount was brittle & fell to bits I took it all off and covered the hole with black fabric to make a nicer finish. Doubt the HRW would work anyway. Just need to check out the hardtop & see what pops into the hole I've covered. (but no rush for that as SUMMERS ON THE WAY yeh hey !).
                          [ATTACH=CONFIG]32848[/ATTACH]
                          joel
                          Joel
                          thats it, mines the one on the left,not seen one like that before
                          thanks again dave
