help with door interior rods pls if poss
    the main rod bar that goes along the door from the interior handle to catch......
    if i slide it side to side it operates the interior locking / unlocking
    but i cant see how the door open handle connects t the door catch? cant see anything on the bar for it?
    Have a look at 76.58.01 here which might help. If you don't get any more help I'll take a picture of my handle later (it's in bits) also a MK1
      wow a online manual!!!!!!!
      unfortunatly does not help though. my rod is attached as i say it operates the lock / unlock leaver just nothing attatched to the door open leaver
        628012 in your first diagram links the 2 IIRC?
          is there a rod that runs along with the bar then? couldnt feel or see it when looked quickly earlier
            the door bar should have a hole, the handle a wire rod put the rod through the hole and push the crimped washer style fixer over the end of the rod.
              my bar is attached at the interior handle lock / unlock side but nothing attatched to door open handle part of it, so looks like ive prob got the rod missing then and whatever connects it each end,
                I'll send you a pic in about 20 mins
                  thanks mate
                    Have you looked inside the door at the bottom? in case one of your small linkages has dropped off, if you cant see or feel down there try an extendable magnet.
                    steve.
                      Sorry didn't have time - car not at my house at the moment. Should be there tomorrow so will try and remember to get pics
                        Not a problem I apreciate any help or advice, I'm going in blind putting back together a car
                          If you look at your picture there's an L shaped bar on the lock assembly,that fits in the door handle,but i think you have another short bar as well, but its not shown on the picture
                          dave
                            I'n not 100% clear what you are asking about...(long night) but I've made a picture of how the door handle opens the door from outside. Inside the rod connects to the inner door handle.
                              For some reason I cant upload a picture. PM me your email address and I will send
