Any experienced Renovo users ?
My soft top was a bit faded and had some white marks. I have cleaned it with the "soft top canvas cleaner" which didn't quite work the way I thought it would having read the destructions. Have now put the suggested two coats of Reviver/reconditioned on. Definitely darker, good. Unfortunately leaves marks where you have tried to do it in "panels" as it says. Bottle says 1 litre should be enough for two coats. I have put two, what I think are generous coats on, still have more than 1/2 litre left, will probably get a third coat on, might then be closer to 1/2 litre left.
Problem is, the fabric has gone from a smooth feel, when rubbing you fingers over it, prior to Renovo products, to feeling like 80 grade sandpaper after ?????
