I took the old girl out for a lovely drive today well it was lovely until i dropped a gear and overtook someone who decided to put their foot down as i pulled out, no matter i thought... foot to the floor head sinks into the head rest and i was gone.... nearly literally because as i pushed the clutch and changed into fourth the engine screamed and scrunched into fourth gear, christ the throttle had stuck wide open, 65 70 80...i tried to brake like an idiot..i kicked the pedal, it was a good job this road had some straight length otherwise i would have had a 300 year old oak as a bonnet badge, still panicking i managed to get my toe under the throttle pedal and lift it which thankfully did the trick.
On inspection back at the pits the only thing i could see that may have caused this problem was the small bracket that the throttle cable connects to on my webers, this has extremely sharp square edges that could have caught on the body of the weber, but not any more tin snips out and they are now rounded off.
I lubricated all the moving parts of the weber the other day and it seemed fine.
If you have a weber conversion then it is worth a check around that area of the weber to make sure you have removed any sharp bits and nothing can catch or jam up, i have run the car with a weber for a few years now without any problems until now...Steve
