Hi ,
Would appreciate some advise , just realised that my oil pressure light doesn't come on when I switch on , so wanted to start by checking out the bulb , first issue , have disconnected the multi pin , but can't seem to remove the actual gauge , it's a late Mk2 , with a sort of spring loaded band around the circumference which seems to hold it in . Have tried a feel gentle tugs & twists , but nothing seems to happen , can only assume there is a trick / hidden catch , can someone let me into the secret please. Secondly and getting back to the main issue are there any other things I should be checking ?
