Kenlowe replacement thermostat
Originally posted by Gilespfr View Post
You can buy direct from Kenlowe. Give them a call they are very helpful and customer focused and if you explain that its failed and if its not too old they may even replace it FOC, they did for me.
Ian.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
I agree Kenlowe are very helpful. They supplied me with a fan and a manual switching kit as I didn't want the fan cutting in and out all the time but just as a back up. Also supplied a very simple set of fitting instructions, which they needed to be. JohnOriginally posted by milothedog View PostYou can buy direct from Kenlowe. Give them a call they are very helpful and customer focused and if you explain that its failed and if its not too old they may even replace it FOC, they did for me.
Thanks for that. Where have you put the switch on the dashboard? Do you have an immobiliser, does it work ok with that??
Giles
Originally posted by Stag About Town View PostI agree Kenlowe are very helpful. They supplied me with a fan and a manual switching kit as I didn't want the fan cutting in and out all the time but just as a back up. Also supplied a very simple set of fitting instructions, which they needed to be. John
Yes I have an immobiliser and no problem. My switch is located under the glove box and is hooked up to the same fuse as I connected the buzzer for my header tank. Can't remember the fuse number offhand but it is the one that only works with ignition on. Last one on the right if I remember. If you need more on that I will go and look.Instructions from Kenlowe were excellent. Regards JohnOriginally posted by Gilespfr View PostThanks for that. Where have you put the switch on the dashboard? Do you have an immobiliser, does it work ok with that??
Giles
Originally posted by Stag About Town View PostYes I have an immobiliser and no problem. My switch is located under the glove box and is hooked up to the same fuse as I connected the buzzer for my header tank. Can't remember the fuse number offhand but it is the one that only works with ignition on. Last one on the right if I remember. If you need more on that I will go and look.Instructions from Kenlowe were excellent. Regards John
