Anyone have any ideas on this please?
Yesterday I noticed a high pitched squeak from the gearbox area when travelling slowly, it was there for about 10 seconds and is speed related. It happened again today and I assumed it was the front universal joint on the propshaft. However, tonight I came to drive the car, put it in gear and got no drive. The engine is being loaded and the revs are dropping normally, but there is no drive to the wheels. It is as if the transmission lock in Park is not disengaging as the car seems to be locked solid (it wouldn't run down a slope). If I run through the gears a few times, so far I have got drive normally and the car drives as usual. It has done the same thing several times tonight.
My first thought was low fluid level, but this is correct. I ran it through the gears several times before checking it etc after an 18 mile drive.
Bizarre, and I don't want to get stranded! Has anyone else had this happen?
UPDATE...! I have just been investigating and I am almost certain that the transmission lock when P is selected is sticking in the engaged position. The car will not roll with N selected, and when it frees it goes with a hell of a bang !
Is it possible to get at the 'lock'? I wonder if it just needs freeing off?
