overdrive/reverse
    overdrive/reverse
    Hi all.
    I understand that engaging reverse with the overdrive on is a bad thing, but out of curiosity, why? What happens?
    Cheers, Mark.
    It is !!! I never heard of that.
      Essentially the unidirectional clutch will be knackered
      I suspect that the best description you will find of what actually happens is on the Buckeye Triumph site, the a-type is covered here:
      ....... Andy
        Originally posted by Stagnant View Post
        Hi all.
        Cheers, Mark.
        A big bang
        The same thing affects both A and J type and there is NO escape ! If you're stuck in overdrive and you go into reverse then the clutch WILL be ruined and you will almost definitely have to replace the overdrive - and hope that the swarf and stuff hasn't got into the gearbox as well (as it shares the same oil).
        I nearly did it once
          Oh! I won't do that then!
          Thanks for your replies.
          Cheers, Mark.
            I'm not sure as to how the overdrive would still be 'in' to even get it into reverse gear. Is that possible ?
              Yes. The OD can only be selected in 3 & 4 because the inhibitor switch allows it. If that switch is faulty (always closed) or by-passed, then it can be selected in any gear, including reverse.
                Ah, now it makes sense Thanks. Had visions of my gearbox imploding next time l select reverse....
                  So Dave, does that mean if I can't select OD in first or second then it won't happen in reverse either? (Not that I'm about to put it to the test!)
                  Cheers, Mark.
                    Sadly, I have done it! It was in a Mk1 2000 but I can't remember why - maybe I didn't have the inhibit switch. It was a long time ago, probably about 1980-ish.
                    It all went into gear OK but when trying to reverse there seemed to be something stopping the car moving. I applied more power upon which the car did move. A bit. This was an 'A' type and the uni-directional clutch 'carrier' (for want of a better decription) and cage fractured. In those days I had even less money than now so I removed, stripped and rebuilt the overdrive. All I replaced was the 'carrier', cage and a big circlip as I remember. Everything worked OK after that until I sold the car and then right up until it was scrapped due to tin worm.
                    As the carrier and cage just fractured, I don't think there was any swarf produced so I was lucky!
                      Cheers, Mark.
                      I can't see how it would. The OD needs 12v to activate the solenoid. 12v is only available to the gear-lever switch if the inhibitor switch on the box is closed, and this can only happen in 3 & 4 as it is operated by the selector rods inside the box. Unless the switch is broke or by-passed, and as you can't select OD in 1 or 2 it seems to be working OK.
                        Thanks Dave. Mine is operating as it should, but I was just curious.
                        Cheers, Mark.
                          Kudos for fixing it yourself!
                          Cheers, Mark.
                            I definitely had it sticking. ISTR the solenoid was the cause of the problem (sticking ?)
                            julian
                              How about if you stopped with the gear in 3 or 4 with the overdive engaged, then immediately put it in reverse?
