No glove box key ????
    Hi
    I have what looks like a perfect glove box lock which closes well, but no key ,if I take it apart will i find a number ?
    cheers Alex
    i took the boot lock and glove box lock to a locksmith, to get a key made
      Yes, it has a number stamped on it under the fixing cover. If this is still the original it will be the same key for the boot.
        I had the same issue when I bought my car. From memory there is a single screw at the back on the lock, remove it and the barrel will drop out. The barrel will have a code on the side (a number starting FS### I think). With this code you can get a replacement key for around £2 posted from Ebay (search FS key).
          Thanks everyone will do
            Just a point, if you get a key DON'T get into the habit of locking your glovebox.
            Shame to say it but given that the security on a locked Stag with soft-top (or even with hardtop fitted) is akin to that of a greenhouse if a scumbag gets in your car having a locked glovebox will merely mean that your dashboard will be trashed as they jemmy it to gain access. Let them rummage through your paper handkerchiefs and bags of sweets at will, remove anything worth nicking and take with you.
            Micky
              Will the boot lock have a similar number? As i have no keys for mine.
              steve.
                Should be the same key as he glovebox unless one or t'other has been changed. Some Stag places have a ton of old keys laying around. I took mine to one and tried every key till one fitted. Once you have a boot key no. time to look in the glovebox lock box for same lock. . . .
                  If have/get a Heritage certificate it will have the key no's on it that the car left the factory with.
                    Locks for gloveboxes and boots (with keys) come up regularly on eBay.
