Seam filling.
    Seam filling.
    For those of you who are thinking of filling the seams between panels, here are a couple of photos of mine.
    The seam between the A post and lower windscreen is quite difficult to get it to look right due to the different angles of the 2 panels. The wing being slightly con caved and the windscreen panel slightly con vexed.
    Black will show up every little imperfection so you may get away with other colours esp white.
    First picture with paint flattened back and second after polishing.
    Very nice, but what's that got to do with anything?
    M
      M
      Read the heading "for those thinking of filling in seams "
      Is it me or this weather
        M
        WTF? Don't you start!
        It's not you Edd or the weather, just the others, they are out there. Don't know why I bother sometimes.
          Don't bite Jeff. I'm sure he is just having a dig at you-know-who, not you. At least, I hope so...............
            Keep going Jeff your highlighting a very important aspect of the stag body and the choices that are available .
              Hope so too Dave.
              If he is then I missed it but an emoticon would have been nice.
              Starting to get fed up with some of the members on here big time.
                I think the space between the front wing and the windscreen frame/front scuttle is to channel the water from the front gutter down to the channels on top of the wing if you block that what happens to the water?
                Once you have built a ship everything else in life is easy
                  I took it as a wind up, even without the emotion. just in case
                    I don't think so Dave, it runs down inside which is why there is so much rot at the top of the A post and inside.
                    Then again, if what you say is true, then it didn't work too well. By filling the seams the water now runs over the top and along the channels to the front and drain away.
                    Mine will not go out in the rain again (hopefully) so shouldn't be a problem. I filled them too as I don't like the gaps and the cracking that happens on them all unless done properly.
                    Jeff.
                      If that's the case then I'm the one whose tired now.
                        .Starting to get fed up with some of the members on here big time.
                        I did say sorry for not sending your screws earlier
                        Glad you're back ok Jeff
                          Julian, you know I didn't mean you, well sort of.
                          Long journey as you know but back safe and sound thanks Julian. Shame you're not going on Sunday.
                          Jeff.
                            Jeff.
                            Thanks Jeff, but can't make Sunday - not if you want to see me alive ever again Our son is getting married on Sunday
                              Funny, I though weddings were 'woman' stuff. Be a man, take the car for a drive.......go on, dare ya........
