fuel pump
    fuel pump
    I still have a fuelling problem with a new ( 4 years ago) electronic fuel pump, any one tried an SU electronic pump that Rimmers are selling ?
    thanks. Peter
    Peter
    I have just changed out my pump to a facet a bit noisy at the start soon settles down. I believe my stag pump has been a bit under powered for my Holley as the stag su pump runs at around 2 1/2 psi my Holley needs around 4 1/2 psi my facet is good for 4 to 7 psi so I have not fitted a regulator as yet will see how behaves on a run
    Also the facet pump is a lot cheaper than a su pump.
    I made a bracket up using the base plate of the original pump and the curved alternator adjustment bracket. I only needed to drill one extra hole in base plate.
    cheers Glenn
      Yup, works well. I just need to know where the fuel in the filter goes overnight now ...
        Boils through the carb into the inlet manifold is my guess.
          Assuming it can leak back through the stationary pump Drains back due to gravity, the filters higher than the tank.
            is this the type of facet pump then ? ebay item 151583876915 ??
            peter
              Yes Peter That's the one
              Cheers Glenn
                Cheers glen, just ordered it.
                regards. peter
