I am about to install the rebuilt cylinder heads and I just would like confirmation that my assumptions are correct and I do not have a clearance issue between the pistons and cylinder head valves. Have I forgotten something!
I have taken measurements of the following:
• All pistons are +0.010” proud above the block face.
• Piston are County LC dished type, STD size , depth dish measures -0.040”
• #8 inlet valve is the most proud of all the valves above cylinder head face at+0.025” *
*Measurements of valve height above cylinder head face taken with camshaft removed
I am planning to use a Payen extra thick head gasket with new ARP head stud/bolt set.
Thank you,
Janner
Thank you,
Janner
