My father in addition to his Stag has a Triumph 2000 manual J type overdrive.
The front gearbox oil seal has been replaced 3 or 4 times now and has always leaked to the point it has contaminated again the clutch plate etc. A hole was drilled in the bottom of the bell housing to give the clutch a rest from fresh oil and instead dump it on his nice painted garage floor.
We are going to do the job and I discovered that he didn't replace the fron output bearing so I am suspecting that there is play and causing the seal to go.
Was looking at the parts and they are the same as the Stag, same part numbers.
So, my question is, how easy is it to replace the front bearing? What's involved? Has anyone done this job?
I always presumed the Stag or Tr6 had a beefier besting etc but I presume us just the output shaft that is bigger?
Also, he is looking at double lipped oil seals as an option, anyone tried these?
Any advice much appreciated as always.
Andrew
Andrew
