Mk1 remote door locking
    I've fitted as above but seem to have the problem that the motor cant overcome the lock.
    Anyone else fitted
    malc
    what do you mean the motor cant overcome the lock,? i fitted it on mine had to move the motor, as it was in the way off window but since moving it ok
    dave
      Drivers door actuator wont lock. It will unlock. Seems not enough ummmmp to overcome the rod. Mk1 is not the same as Mk2 rod
        I didn't think you could fit remote door locking to a Mk1 as there was only one actuating rod which lock but opens the door as well. I thought people who tried to do this found it opened the door when triggerd. Well done for overcoming that problem,if indeed there was one. I have central locking and window closing wired in with the alarm but mine is a Mk2 with two operating rods. Graham Slow typing again
          Got it. Took all apart and greased the ef out of it..
          Graham, l bought the system from Ian at Monarch. Works well on Mk1 and 2. How does yours do the windows, how does it know to stop ?
            i didnt use the rod to connet my motor, i have seen it done that way,i welded a hook on to the lock mech its self
            dave
              Hi Malc
              I've got this kit sitting in a box to be fitted one day. Did you take any photos of the installation?
              Cheers...Al
                Anyone else fitted
                Hi I tried I could not get it to both lock and unlock, slung it in the bin ,Cheers John
                  Anyone got any info on this kit how much where to get it etc,etc.
                  cheers steve.
                    cheers steve.
                    See post 5.
                      Got it. Took all apart and greased the ef out of it.. Graham, l bought the system from Ian at Monarch. Works well on Mk1 and 2. How does yours do the windows, how does it know to stop ?
                      Sends a -ive timed pulse from the alarm mainframe. Does the monarch one lock and unlock on a single rod lock?? Cheers Graham
                        google monarch stag....simples
                          Yes, it is a good system. Motor rod attaches to door rod as per normal. comes with alarm, a couple of relays, some wiring to be done. Mines in bits so made a custom loom under the dash for it. I did drill a 1" hole to access the rod screws more easily.
                            Originally posted by Arbman Al View Post
                            Hi Malc
                            Cheers...Al
                            Hi Al.
                            I finally fitted mine over the winter, screwed motors to door just below rod and put a slight double bend in locking rod to meet existing rod. Join was below an existing cut out in the door, so no extra cutting. Used thin wall cable and ran the 2 wires through centre of existing moulded grommets. My alarm has necessary output to drive motors. Simple, wish I had done it years ago. Purposely have not included the boot.
                            had a photo of lock mount somewhere will try to find it.
                              I,m really interested in this post so any pictures would be great I think I might do it as a winter project , I was trying to pretend I would enjoying using the keys but in reality it would be useful .
                              Edd
