Hi. I'm new to Stag ownership & this is my first post! I have just got the brake failure warning light working (the bulb was missing!). The light comes on with the ignition & goes out after start up but when I went for a drive this evening, I noticed that when I came to a stop, the light flickers and then comes on. If I put it in 'N' or 'P', it goes out but in 'D' or 'R', it comes on. When I pull away, it goes out. I guess it has something to do with the slightly lower RPM in 'D' & 'R' when stationary but don't know how this relates to the brakes! Any advice would be appreciated.
Brake failure warning light
Mine was doing that and I realised the very dim, green oil light was also flickering, so it was operating in conjunction with the oil light, so low oil pressure at idle.
I fixed the issue on mine by re-stowing the oil dipstick properly to recreate the felt seal around the dipstick hole.
Hope that helps
Ps mine is also auto, so didn't happen in neutral or park, but did at idle in any of the drive gears
Originally posted by V Mad View PostThe Mk1 warning light design is flawed becuase it does not apply the full voltage to the OIL warning light and so it never lights up brightly enough. I converted mine to the MK2 system which overcomes this fault. It's an easy wiring mod which gives full brightness to the OIL light.
There all Flawed if you think about it, Do you really only want to know your oil pressure is failing only after it gets to very low single figuresWise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
I've got a combined oil pressure and water temp, I'm very happy that a quick glance every so often reassures me about the health of the engine!!
FullSizeRender.jpgRichard
