Not Stag related, but I acquired a TR8 convertible at the beginning of the year and am having problems with the low ride height. I scrape speed bumps and even the road at times with uneven camber. I replaced all the springs and shocks with standard items - same size as original, with polybushes, although the springs seemed to vary by 1 or 2 cm from newIMG_0097.jpg.IMG_0181.jpgIMG00645-20150124-1548.jpg
My ride height is lower than practically every other TR7 and 8 I have measured, by 50mm to 100mm. The car does have a non standard exhaust that makes matters worse, as it is the lowest point under the car. I have a new stainless Rimmers exhaust to fit that should help a little.
My question is if anyone has used these:
to fit under or above the springs to increase ride height? I have also seen aluminium ones and one of these was fitted to my Stag for some reason - now removed.
I know it is not a Stag but the principle is the same. Any thoughts appreciated.
Mark
Mark
