Hi there, I have spent several hours trying to solve why my door won't open (unlatch) and having removed everything from the door mechanism I can now conclude that it is the actual latch itself and I need to replace it. The only problem is the door is closed! It will open to the primary stage so there is a bit of wriggle room but even with the 'pin' up as far as it will go it wont fully unlatch. It seems I have two options:1 try and drill through to the mechanism from inside the door so I can somehow manually release it or 2 force the door with an air wedge and replace the already broken mechanism. Any feedback would be great especially if you've had a similar issue and also to the effectiveness of an air wedge.
btw it is a mk 1 stag but I'm not sure of the lock...?
