mixture needle just turns
    hi all, trying to adjust mixture, one carb is fine, the other just turns and turns and turns. can this be fixed of is it a new piston? if so how do you get out?
    thanks in advance
    mark
    It just means the adjusting nut has "run off" the thread that holds it and adjusts it. Have a good look at an exploded diagram (Rimmers? ) to see what I mean.
    Good info here: http://www.buckeyetriumphs.org/techn...bsI/CarbsI.htm
    You don't need a new piston, just a repair to the one you have.
    HTH
      HTH
      Hi wilf, thanks for the reply. I have looked at the web site you suggested and rimmers. I understand now, however, how do you get it apart?
      Thanks
      Mark
