when you take the vinyl covering off,be careful as its stuck in every curve, theres loads of hog rings fixing it to the frame as well,if your unlucky like me the foam ripped a lot,so had to lay more foam on top,when refitting the vinyl cover use hog rings again or cable ties
As a matter of interest, what glue did you use when re-fitting. I am looking to do my front seats. Have the foams now but cannot make my mind up on glue and where to get it from.
Let me know anyone cheers
Jonathan
Jonathan
i used evo-stick from a tin,don't use the spray,its to fine eg not enough glue is used
