I am afraid that my 70 year old memory has let me down big time. I must own up to being a complete plonker. It is in my defence 22 years since I was in the oil business. Hopefully you will all give me some credit for owning up to being a forgetful old twit!
Corrections in red below. I felt I should be big enough to own up before anybody damages their auto boxes.See also comments about Rover SD1 below.You may all be as rude as you like. I will take it manfully on the chin!!
Grovelling aplogies once again! I was talking to a fellow member last night who had apparently been told by somebody in the club that DEXTRON (sic) was an additive in automatic transmission fluid which could cause damage to some Borgwarner auto boxes. This caused him to have his gear box drained and re-filled with Ford ATF* which , if my memory serves me correctly (and they haven't changed requirements) used to be DONAX.
Having worked for Shell Retail Automotive Lubricants for 21 years, both in sales and marketing I can assure everybody that ..
1 there is no such thing as DEXTRON. It is a common mis-spelling of DEXRON.TRUE
DONAX FOR BW BOXES[/COLOR] Other makes used DEXRON. A different formulation.
For the full story see...
You will see that due to the age of ALL Stags that DONAX is the correct grade for Stags when new.
Dexron & Donax are both basically hydraulic oils. The correct type is essential for the gear box requirements. DO NOT put DEXRON in your Stag auto box!
However, as far as the power steering is concerned it really doesn't matter as the oil's primary function is as a hydraulic oil to power the steering ram, & secondarily to lubricate.
But there is no heavy loading on the rack as there is in a gear box. So it is not vital which one you use.
Disclaimer.
I should point out that I left Shell in 1993 so the information above was correct at that time. Therefore it does cover our cars. Current requirements and specifications may well have changed.
Disclaimer.
