Afternoon wise ones. Finally got the Stag back from Enginuity after an instance of brain fade, inadvertent reverse selection and picking bits of the garage out of the driver's side (don't ask!). Enginuity did a brilliant job of the repairs and addressed a few other issues at very reasonable cost, too.
I didn't ask them to do any mechanical work and took the Stag out for an Italian tune up earlier in the week. I am running a Mark 1 with a Mark2 rad, no viscous Dan, but a BMW fan in front of the rad and a variable stat filled with Evans Waterless.
Although ambient temp was about 22c the gauge did rise to about 4/5ths with the fan going full belt. Curiously, switching the heater on didn't make that much difference. Spanking her at 70 plus (3500RPM) did not help either. Only dropping back to 40 -50mph (2000-2500 RPM) reduced the temp to just above the mid point (which is where it's always been). I have never taken the car out for a sustained 2 hour blast before.
I suspect that this is the problem of air not getting to the bottom of the radiator and have ordered an LD secret spoiler as it's a cheap fix. But as a Mark 1, there's a lot of space at the top of the rad and I was wondering about sealing this with hardboard sheeting and possibly going round the rad and trying to force all the air through the rad. Is this a bad idea? Has anyone else done similar things?
