This is how I have always applied coach lines.
    watch
    +1 ,The only way to get it right, just don't open the doors until you have cut the tape, don't ask how I know
      Jeff
      i was expecting to see you fitting the pin strip
      dave
        Brilliant, thanks I am just about to do mine
          Just dip a paintbrush in a pot, clamp the brush at the right height in a workmate, and drive past it...... Just make sure the ground is smooth or you'll get a bump in the line.
          If you want a twin line, use 2 brushes
            Double post
              We don't even get a break from you when out of the country!
                When applying in the cold ensure you warm up the tape to room temperature. I'm sure these tapes sit in warehouses for ages as one reel I had was really britle. Frustrating at the time it snapped half way. I toyed with setting up my laser level but in the end a good eye is all that's needed.
                Edd
