Manual gear box
    Manual gear box
    I am thinking about changing my auto box to a manual box if anybody has any advice like how difficult it is this would be much appreciated. And also would my starter fit because if I am correct isn't the starter on the other side.
    the starter will be the same,theres a few parts your need for the conversion
    dave
      You'll need a good box c/w overdrive, engine to gearbox adapter plate, flywheel, clutch, pedal box, prop shaft, wooden gear-lever surround, clutch master cylinder, slave cylinder, hydraulic pipe and gearbox wiring loom. The starter motor doesn't change sides.
        Would any body know where I could acquire these parts are they readily available or am I being a bit hopeful
          try the tim,look in the for sale section on here,he was selling a gearbox, he may have all the parts you need
          dave
            I recently had mine converted over. Granted, Robsport did it for me, but they didn't have any problems getting the bits.
            Hope that helps.
              Was the conversion expensive? It sounds it?
                The actual conversion cost wise was similar to the cost of converting from a 3 speed to a 4 speed auto box. Roughly £3000. That included a refurbished gearbox and overdrive, the clutch, pedal box, a load of other stuff like gear surround, labour and VAT. I am really pleased with the conversion. I had some other work done at the time (polybush, steering column rebuild, and diff/driveshaft) combined it has transformed the car.
                I always wanted a manual. However when I was looking for the car, the advice I was given was 'get the best you can afford.' In my opinion, mechanical things are easier to repair than bodywork, so I specifically looked for a solid car. I read Edd's stag project with interest, but knew I wouldn't have the time, knowledge or patience to do what he did. Total kudos to anyone who can weld. I would probably end up catching something on fire and it would look awful when I had finished.
