Morning all. My wiper will not switch off once it's been switched on. I have changed the switch. Eventually, I gave up and pulled the fuse. I discovered that a spare fuse had fallen inside the cover and was making contact between the wiper fuse and the next fuse along - to the point that cover had partly melted.
Took this out put wiper fuse back and she still won't turn off. If you switch off the ignition she does not park.
If she's left a while with the switch off she usually won't star the wipers until the switch is engaged whereupon she won't turn off again.
I believe that the circuit is permanent live feed through the ignition switch and the wiper switch simply earths? Any suggestions?
