adjust doors
    adjust doors
    hi my garage guy just rang me to say he cant adjust the doors the car had a respray when I bought it and they just bolted the doors on is there anything hes missing there quit a bit out and I don't like slamming them like this
    any help would be appreciated
    richard
    Hi Richard,
    There is quite a lot of adjustment. The hinges are mounted to the a-pillar on captive plates which allow some movement. The hinges attach to the doors with more captive plates allowing movement. Finally, the door locks and plates can also be adjusted.
      yes will get down the garage later myself see what hes on about your car looks nice mine is also carmine the colour's definitely growing on me
      thanks
        I made the mistake of taking a door off at the A pillar which meant a lot of messing about to get it back in line, this might be how yours has been taken off Richard. As Dave says there is a lot of adjustment, just takes a little while (and patience - something in short stock in my case) to get it sorted. I tried to move one variable at a time which eventually worked. Good luck
        ps can someone move this to the main forum?
          You can also gain more adjustment by elongating the slots on the hinges themselves. A small pry bar wrapped in tape is handy too to move the hinge on the a post with a slight bit of tension on. Otherwise every time you fully losen you start from scratch.
          You can also use a felt too pen to mark your last position.
          Good luck
          Edd
            we cant get the door pillar hinge off due to messed up screw drivers side.
            the passenger side door the top window side is hiting the chrome bit by soft top looks like I will need to find someone who knows more about this because I hate slamming the door its not right maybe stag body shop. or something first the project was going sweet but lately 1thing after another
              Yes as you have pointed out the adjustment of the door might lead to the window frame also needing further adjustment.
              Also the lock catch. I spent ages on mine and even shortened the lower frame bracket to allow the frame to travel towards the rear of the car. Maybe you have a keen local member who might be able to help ?
              Edd
                Edd
                Edd
                i did that as well,got the idea from you
                dave
                  as already been said, doors can be a pig to get right,where is the car ?
                  dave a keen local member
                    Edd
                    dave
                    Well done Dave that's what the forum is all about. I have learned so much on here too.
                    Edd
                      hi Dave yes I should be getting it back next week im in Hayes
                      richard
                        richard
                        also thanks for all your replies my garage is taking forever with the car will be glad just to get it back off him haven't even driven it properly yet
                          im in Hayes Dave car should be back next week
                            let me know when you get it back,and i can pop over
                            dave
                              thanks mate I will
