I have standard alloys and have fitted the stainless steel wheel nuts that you can get from most places, mine I think came from Paddocks. When fitting my wheels I use 2 steel wheel nuts as they have a taper and centre then wheel on the studs. Last night I loosened very slightly all four wheel nuts to see how much anti clockwise / clockwise play there was and was quite surprised as to how much I had. I haven't measured the play.
The standard wheel nuts made of alloy are different design to the stainless nuts I have the difference being the alloy ones have a tapered collar, whereas the stainless don't and just clamp the wheel to the hub.
Is this what the rest of you have or can I buy other wheel nuts with tapers made of stainless steel?
Andrew
Andrew
