My restoration has been stalled for about 18 months whilst trying to catch up on 3 years on excessive to the states and showing two litters of Clumber Spaniel puppies!
So, I went back to the lock up this weekend and re-introduced myself to the Stag!
So far I have removed the offside outer sill to find the inner reasonably sound apart from an area around the drivers door.
The floor has rotted out as well as the end of the two outriggers in that area.
I have a new floor and two new outriggers, but it seems a shame to have to remove it all when it's only the last 4" of the outriggers that has rotted. So....
My plan is to cut back the floor to good metal, probably about 4" in from the inner sill. At the same time, only remove the rotten part of the outriggers, then cut the new parts to fill the space, use a joggled edge to overlap the old and new and seam weld the lot.
Is that a reasonable approach and if you want pictures it will be a few days!
Peter
P.S. The "other" Stag is still in disgrace with a stuck clutch and blown master brake cylinder!
Peter
