Tonight I started to make a thin wall cutter for cutting corrosion around head studs....to assist head removal.
Bore of 11.4mm seems to clear a new stud so the cutter was drilled 11.4mm
But the outside diameter target size is a lottery.
The reference head I have has various stud diameter holes that vary from diameter 12.5mm to 11.6mm, so now I'm unsure what the best size is to turn the outside diameter to... any advice in terms of any other reference heads out there?
I'm thinking of trying 12.3 diameter...what says you?
Thanks for any useful sizes.
