Headlamp bowl to front panel Gasket - fixings
    G
    Originally posted by Neil W View Post
    Got the all the front lights off the car ready to underseal the wheel arches / front panel.
    Don't want to blabber the wiring / radiator etc when spraying the area.
    The light bowls were not fitted with gasket which I will fit & were bolted instead of using the square plastic fixings ( as per grill ) which I will also fit.
    Questions is - when the plastic plugs are fitted they sit proud of the panel so the gasket won't sit flat against the panel - so do you make the hole in the gasket larger so the plastic square face is clear of the gasket & the bowl face will sit tight on the gasket & panel ?
    when i have fitted the plastic plugs for head lamps,they only sit proud of the panel by 1-2mm,which didn't affect the gasket
    dave
      dave
      Yep, I'd go along with that. I seem to remember that the rubber was thick enough and soft enough to absorb the small amount that the plug protrudes by.
        One job leads to another so tidying up wiring loom now !
        Ha ! Tell me about it
        I ended up refurbishing my headlamp bowls after just changing a bulb that had blown. However, with them out I could see what the front side of the inner wheel arch was like and it needed rust repairs - whilst I was cleaning the area up the front of the wheel arch I noticed rust on the rear and attacked it with a screwdriver. The rusty area got bigger and bigger and went down to the back of the wheel arch.........then into the sill......back along the sill......into the front outrigger
        I managed to repair it all but it all started with just a blown bulb . I hope you don't find the same !
          top tip, screws that hold the grills into place can be a swine to work with. an inch of insulating tape folded into quarters with a 2mm hole drilled / punched through the middle will hold the screws in place while you manoeuvre the grills past paintwork etc
            Good idea - even better, I reckon, with a small square cut from a plastic ice cream or butter container.
              +1. Been doing it that way for years. It takes only a few minutes to replace all the grille sections.
                Yea, yea, yea!
                  +2
                    BluTack for screws and copper slip for nuts (a dollop in a socket will hold a nut in place for a long time)
                    I ordered a set of new gaskets when refitting the lights and found they were thick enough to compensate for the slight protrusion of the nylon blocks.
                      Yea, yea, yea!
                      Yeah.........
