2 x left hand carbs
    2 x left hand carbs
    hopefully the first of many questions .
    ok we got her running BUT after thinking the carbs are really in great condition I go to put the advance retard on to the right hand carb and guess what no connector.
    So my question is can I drill and tap a hole fore the brass connector or do I need to find a right hand carb ???
    have i missed something here ? I thought the vac take off for the dizzy came from a centre tapping in the pedestal on the strommy set up and not from the carbs ?
      Yep, brass stud on the pedestal
        Boy, am I glad that I'm not the only one . I thought exactly the same as both Bob and Steve and even posted that in my deleted post above.
        However, for some reason, I then doubted my sanity and went and had a look at my car and saw that the outlet that comes off the pedestal is for the temperature control on the air intake, whereas the vacuum advance is, in fact, off one of the carbs.
        Amazing how we can still go wrong on things that we think we know like the back of our hands
          I would have been with the three of you, I would have been absolutely certain that the take off on the pedestal was the vac advance. But now you have said it, I can't think where else the intake temperature control would have come from. Bizarre!
            oh well just as well i don't run stroms then and haven't for donkeys years i got a holley fitted ,and the vacuum take off for that i have fitted to the bottom rad hose but i get a lot of flooding problems !
              Yep, I was so convinced that I've just gone out to check again
                :d:d:d
                  Er.... that looks like the Vac advance Julian?
                    Yep, and it's coming off the right hand carb. It wasn't easy to get a good pic.
                      Doh Just fell in......
                        What coolant works best with that Steve, OAT or IAT
                          Julian. Left hand carb. surely?
                            drivers side carb is correct
                            or offside
                            alan
                              This whole thing was doing my head in last night !!!! I've now treble checked and it IS the right hand carb.
                              What may have confused things was that the only way I could get a half decent picture last night, having removed the breather pipes, was from the front of the car looking backwards.
                              Just to confirm my sanity, I checked the ROM and found this:
