Hi Folks,
Long time reader and first time poster. I've gained a mass of information from the forum since I've had my car, but am now at my wits end with the current problems and hoping for some advice..
I HAD a perfectly functional 73 Mk2... however I wanted it to be the best it could be. Compression was good all around (around 155) except for cylinder 2 which was down to 100. I decided to investigate..
Anyway, one thing led to another and I ended up removing the heads and replacing all valves, springs and lightly skimming the heads. Cant remember the final measurements of the head but one side needed a thick gasket and the other a shim saver and thick gasket. All valves were well and truly watertight before I put the heads back on.
I also decided while I had the heads off that I may as well replace the rings. I pulled the pistons which were in good shape and gave the cylinders a light hone. The bores were within spec so I just replaced the rings with Grants.
So with it all back together, the compression is a mess.
Cylinder 1 2 3 4 5 6 7 8
Dry 0 0 150 95 40 25 60 30
Wet 0 0 165 110 65 50 75 50
So no compression up front and a real mixed bag elsewhere, with wet results better in all cases. I just cant understand it..
Firstly, with that compression should I even expect the car to start? because its nowhere near starting at the moment..
Secondly, surely the only way I could have such poor compression is if the timing was out?
I did do the timing gear and chains while I had it stripped down. However I visually confirmed that TDC on cylinder 2 aligned with the crank marking. As it stands now the cams are both aligned when the crank is on its mark at TDC. So unless Ive missed something I've got the timing right..
Another possibly relevant piece of information is that the valve clearances are all over the shop at the moment. There was a point before I put the heads back on that I turned a head over and of course all of the buckets and shims fell out. I was in a hurry as was moving house so put them back on randomly and haven't corrected clearances yet.. Could incorrect valve clearances cause the compression issue?
Appreciate any thoughts!
James
James
