As the title suggests, made an interesting discovery today after trying everthing to stop a slight wobble. The next step was a new set of wheels, but i have sorted it at last for the cost of a bit of etch primer and a sanding disc.
The wheels had been reconditioned at some point before my ownership, and pwder coated front and rear. That was the problem! Where the wheel mounts on the hubs had also been painted...... badly, as the paint was very hard, but not level. Where they had been hung to dry in the oven, the coating had sagged and ended up thick at the lowest point. His led to the wheel not being square onto the hub and no matter how well balanced they would run out of true.
Just a point to check if you are having wheel problems
