Stag on hydraulic Ramps
    B
    They're good - How much are they normally?
    Good to see you and I have the best colour for our Stag's!
      I have some of those also
      Loads of height for gearbox removal. low enough that the car can roll unassisted onto the ramps. tow rope makes it even easier.
      As my ramps raise the cars needs space to roll back a little, therefore you cannot / should not use handbrake nor chocks on the rear wheels. causes damage to the ramps. Once up then chock the wheels etc
      Very useful height
      Works on gravelly surface
      Ramps can be independently jacked at different heights
      Only one lock off position which is at maximum height.
      Still love em though
        Very nice, Neil. You'll now be able to get some polish on that car, it obviously needs it........
          Are these the ones? http://www.cjautos.eu/cr06x_p/cr06x.htm
          Might have to buy myself a Christmas present...............
            Nice piece of kit but get proper front chocks. That puny piece of wood will NOT stop it rolling!
              They look really good, but 100kg!!! Are they made of Plutonium?!!
                I have the windup ones. http://www.cjautos.eu/product_p/cr02.htm
                  Lighter, cheaper and carry more weight
                  But dont have the roll off protection and still with only one lock off point at full height
                  recommended by me though
                    I have had a set for a few years now. If the new ones lift vertically, then they are a big improvement. My design pushes the car along as the ram goes up and you have to make sure that it is not in gear or brake on or wheels chocked otherwise you build up a huge force and suddenly the ramps move, which frighten the living daylights out of you. No problem with the car rolling with the old design as the wheels go over a lip on the ramp which holds the car in place, but getting over that lip sometimes just pushes the ramp away and you have to start again. However, they really make life easier.
                    I am building a new garage and will put a 2 post lift in it. Not a lot of difference in price as compared to some of those scissors lifts.
                        Look really good but as said get bigger chocks at the front, pref wedge type, 6" high tapering down to nothing. Used them all the time in the fire service for safety.
                        Car looks great.
                        Jeff
                          Originally posted by MandM View Post
                          Thats the ones I brought on eBay for £250 a few weeks ago been used once by previous owner like new
                          Cheers Glenn
                            [ATTACH=CONFIG]35691[/ATTACH]
                            Out of all the garage lifts the two post lift is the most demanding for concrete quality, depending upon which model you'll buy I think you'll find they all need 3000 LB plus concrete for their base. Don't even think of mixing it yourself even if using a mixer and I'd recommend you use an experienced architect to plan the concrete reinforcement. There will also likely to be a requirement for ground anchors for the posts (5 bolts) for each ...oh if you don't comply with the appropriate fitting requirements they'll try to kill you, ali baba may not be your friend here.
                            Micky
                              I have to congratulate you on your car
                              Looks very nice.
                              Who done the paint job
