I just took out the upper steering column to install the steering column bush kit from LD. I have not dismantled anything, but when checking I can find no play in the front where the parts for the column bush kit go (that is not to say there is no play there) but I find lots of play in the sliding joint between the two outer tubes on the column. The play is where I point the screwdriver in the attached picture. I have also snatched a picture of the outer column from Rimmers. This play is probably felt more by the fact that I like to have the steering wheel all the way out when driving.
Is there anything to be done to this? It seems there is no bushes or anything that can be changed. I am thinking about peening the outer tube, is there any possible problems associated with this? I am thinking about the steering column not collapsing in a crash, but on the other hand, as long as the column can be adjsuted manually that should not be a problem. The other option may be to change the outer part completely.
