Having now had the cylinder heads overhauled, after a blown gasket, I’m now rebuilding the engine, which is a first time for me.
Regretfully, my note taking during dismantling was inadequate and I’m unsure where the battery earth lead was originally attached. I have asked around a couple of the other members and they have told me their ones are fixed to the lower steering pump bracket bolt (seen as a yellow in the picture). I have not been keen to fix mine here as this is to a bolt in elongated slots for belt adjustment.
I accept this would probably work ok, but I don’t think this is not actually the correct location point.
I have temporarily fixed mine to the alternator bolt(red), but am not happy about it. So, I have queried this with a well respected Stag dealer who has told me the correct mount is ‘to the top timing case bolt just above, adjacent to the alternator mounting lug’ My interpretation of this is that it is shown in the picture as the lower of the two uncoloured UNF bolts numbered No 3 which are 3½ inch(8.9cm) long. I tried to fix mine there, but found the small bit of thread at the very end in the block is stripped and won’t tighten up. Is this a common problem, hence the fixing to the steering pump bracket? Also, what options are there, as I think to Helicoil at this late stage is not viable? Thks Tony T.
