Valves
    Valves
    In preparation for getting my heads reconditioned, where's the best place to get some exhaust valves
    Is it a good idea to replace the studs or not ?
    Len
    Most of the main suppliers will source their valves from the same places, though the ones I had from James Paddock were a slightly different shape and gave slightly improved gas flow when tested on my flow bench.
    Personally I only replace the studs if they are corroded.
      I am using Paddocks Valves no problems up to now. As for the studs, I replaced them for stainless ones from Wards because they have a hex head, and used the original bolts following a good wire brush up.
      James
        thanks for that, Paddocks it is then
        Lem
          +1 for paddock valves. No probs since rebuild
            I sourced original trw valves from a stag stockest that no longer deals but had stock when I was looking.
            If memory serves me right it was t & m garages they might be worth a try
            0121 526 3496
