Gear box leaking oil
    Can anyone recommend an additive to the gearbox oil to stop or reduce leaks ?
    This is only a stopgap , to get me through the next few months before it comes out in the spring.
    It functions well, isn't making any nasty noises , but does drop a bit, so just want to be on the safe side til the spring.
    Manual or special needs box
      Still buying shoes in pairs, Proper car, proper box....I'm not retired .....yet��
        Nothing wrong with a slush box
        Where is it leaking from I would be very careful if you do put some snake oil in it and make sure it's suitable for O/D use.
          if it were me I would keep an eye on the level and invest in kitty litter / drip tray
          Where is it leaking from on the gearbox?
            Already invested on the drip tray , difficult to see where the leak is , but towards the back of the box / propshaft area judging by where the drips hit the ground,and tray. It's dropping onto the exhaust so after a run there's that lovely burning oil smell outside the car .
            I think keep topping up is the best option....net done that before on this car....every days a school day ��
              If it's a small leak it may be the speedo drive. I have to do mine in the spring. I was told a felt washer might need replacing. I hope it's a simple fix for you.
              Edd
                Many thanks for the info, just about to go under and have a look.....at least I will be lying on the £30 Amazon carpet on the garage floor .....best investment yet ��
                  Leaking from the adapter plate between gearbox and overdrive is common, and only a strip down can cure it. If it is the rear tail shaft seal, this is 'doable' in situ.
                    I've got a slush box in mine and it's leaking from the banjo bolt / washers at the end of the autobus dipstick tube. That also leaks onto the exhaust
