Andrew kindly lent me his compression tester so I found an hour this afternoon to check each pot; they all came up at just under 9bar so not a problem there.
What I did realise though that when cranking the engine (coil and fuel pump disconnected) to check the compressions there was a distinct rumble coming from the engine - foot on the clutch or off it made no difference.
So, I'm thinking I have a crank bearing problem again but it was properly checked, polished and new bearings AND I had the rumble with the old different crank.
I guess the only answer is engine out and stripped again but having done it once and I still have it I'm at a bit of a loss to understand how the crank can be the problem. Also, the oil pressure is excellent....
Baffled I am!
Baffled I am!
