Is the choke switch located near the radio aperture behind the choke knob? If yes, is it accessed via said radio aperture?
Choke Switch Location
ham204stagTags: None
ham204stag
Originally posted by Neil W.... use a small allan key to loosen the switch clamp to the cable
DrewThe answer isn't 42, it's 1/137
Yes, if you can get the bezel off, it's possible to push the whole choke cable head forward so that it then dangles into the footwell. Disconnect battery first or it is likely to blow a fuse as it touches the footwell lights. Incidentally, as I couldn't tighten up that bezel enough, I tightened up the nut on the inside of the console; very difficult to get a spanner on, but the tool used to adjust valve clearances on a Ford Pinto engine fitted perfectly as though it had been made for the job! (this was, however, all done with the console pulled out a bit)
Is there a tool or trick to grip those bezels without the risk of slipping off and putting a score in the veneer?
Originally posted by dasadrew View PostMy old original switch and two NOS ones in original bags from Rimmers and Paddocks all had a normal slotted grubscrew (flat blade screwdriver). Not saying there aren't ones with Allen key out there but it's a fiddly operation so, if you can't get an Allen key in it might be worth trying a normal screwdriver. Hats off to the guys who do this through an aperture - I couldn't manage that with my sausage fingers and as Zoony the Lazoon wasn't around I ended up half disasembling the console!
Drew
The upside to that was when I fitted a Volvo ht I was able to use choke feed & light as a low level warning.
Rob
Originally posted by dasadrew View PostYes, if you can get the bezel off, it's possible to push the whole choke cable head forward so that it then dangles into the footwell. Disconnect battery first or it is likely to blow a fuse as it touches the footwell lights. Incidentally, as I couldn't tighten up that bezel enough, I tightened up the nut on the inside of the console; very difficult to get a spanner on, but the tool used to adjust valve clearances on a Ford Pinto engine fitted perfectly as though it had been made for the job! (this was, however, all done with the console pulled out a bit)
Drew
Ian.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Originally posted by dasadrew View PostIs there a tool or trick to grip those bezels without the risk of slipping off and putting a score in the veneer?
Drew- I've seen an advert for a tool specifically to undo the bezels. Bear in mind that similar ones were quite common on many BL products.
Having said that, I've always managed with a small electrical screwdriver, sideways into one of the grooves and tapped sharply to just do the initial loosening.
ham204stag
Originally posted by dasadrew View PostDifferent type of bezel. Ford use a type of ring nut with two cutouts in the circumference and I reckon that that tool is designed to fit those
This might be it.
