Question. Radio
    Question. Radio
    Hi all
    Happy new year to you all.
    I am getting interferance on my radio when it is fitted in the appature. Ita fine if its out of the hole by about 6 inches. Question is, will a surpressor fix the problem, or will i need to do somthing else as well. The ground on the aerial is fine.
    Dave.
    Hi You might want to fit an inline choke to the power feed line ,plus use a suppressor on all your electric bits until the problem is eliminated ,plus you can use r-spark plugs ,good luck
      Thanks Alex.
        Hello Dave, Haynes Manuals have a good section on fitting radios and suppressing interference. Section is common to the whole series, so it doesn't have to be a Stag one.
