Biggest improvements in 2015 - what were yours?
    I thought I would start our own annual review, themed along the lines of the most useful stuff you did this year to improve your car. I did quite a bit, but the single biggest improvements were these (relatively) simple ones:
    - new HT leads, distributor cap, rotor arm (regained about five horses and clean revs all way)
    - new track end rods and ball joints (really tightened up the steering)
    Not very expensive but real impact on driver enjoyment of the car (all sourced from Peter at LD Parts).
    PK Happy New Year!
    Mk 2 1975 TV8 Mimosa
    Mine was MOT.
      Mine was removal of the ash tray and replacing it with an IPod Touch, fixed behind the aperture, so only the glass panel shows. Amplifier in the boot with large Bass speaker. I can now enjoy crystal clear music all controlled from the iPod or indeed any iOS device that is in range of the car, ie passenger.
      Mr Blue Sky all day long for me in the summer ! And yes I can still turn off the music and listen to the music of the engine whenever I please.
      Dazza
        Overhauled cooling system: replaced water pump with external electric pump, replaced viscous coupling, installed auxiliary electric fan and installed landerover type expansion tank. Changed all coolant metal piping to shiny stainless steel.
          New front seats and Hood this year from South East Trimmings.
          Highly recommended and he doesn't use a club hammer to fit them..........
            Ouch!
              Ouch!
              But true,
                But true,
                But I know differently
                Happy New year Ian & Pat
                  Putting the engine back together helped quite a lot.
                  Jameds
                    Overhauled manual gearbox, renewed clutch and pressure plates. Rehoused the battery under the spare wheel. Fitted new window 1/4 light rubbers.
                    Cheers Ian A
                      Finishing the project Stag after nearly 3 years work.
                        more info on this change
                        Dazza
                        Would lime to see more on your iPod mod to the ash tray.
                        Any pictures etc
                          Instrument illumination with green LEDs & cointray / heater control illumination.
                          New indicator / headlamp stalk.
                            Any pictures etc
                            Same here, I like that idea, was going to do similar with a sat nav but decided the hole wasn't big enough. Might have to have another look now
                            James
                              James
                              A lot of people do this with LR Freelander 2s, they fit a Tom Tom in a dash recess, the reason I'm saying this is they have found a way to upload the LR green oval as the home screen so I would think it could be substituted for the Stag emblem which would look cool
                              If anyone is interested I'll try and find a link
