Had a chance to play with the Stag this morning and just have couple of questions.
I have the car jacked up on axle stands and chocked at the front with objective of trying to see what causes a resonance when driving, especially under load. When the car is running in any gear, I get to a various speeds and I can feel the car picking up a rhythm at the back as if it is bouncing. You can easily see it in the door movement if left open. It can be felt through the driver seat. Its not mechanical and doesn't feel like anything is touching but does feel like the wheels / tyres are oval.
If I remove the wheels, it goes so it is definitely the area. I have removed both wheels and used my new DTI to see if there is run out on the drive shaft flange as can be seen in the first clip. Presume this is acceptable tolerance?
I have cleaned the inside of the wheel and the drive shaft flange so happy that the wheel is sitting cleanly.
The trolley jack by the way is not touching the car, but when its running I can hear a metallic clatter which is irregular, is this the nearside wheel catching up with the offside?
I know it would help to try some minilites to rule out wheels and tyres but for today, this is where I am.
Any thoughts appreciated
Andrew
Andrew
