I want to change from the original fit type oil filter where you fit a new canister , to a twist and dispose cartridge type, Is there a kit to make this happen , or does the new cartridge just screw straight on ?
Oil Filter change
Thanks chaps, I'm just gonna revisit the 70s , and remind myself how hard it was changing the canister type ( admittedly on a mini) ......before I decide whether I splash out on the conversion. On my mileage , I'm only gonna be doing this about every two years , just long enough to forget the pain
Good luck with the head gasket Richard, is the tow bar on yet ??
I heard as rumour that o ring leakage is often due to the bolt in the middle of the adaptor unscrewing from the block when the filter is changed. The first time I changed the filter the housing was indeed wanting to unscrew. To prevent this I put a smear of flange sealant on each side of the o ring (hylomar non setting type stuff) and loctited the central retaining bolt. I also tightened it a bit tighter than it said on the instructions and haven't had a problem since.
These stag filters seem mega tight after they've been of for a few months compared to other spin on filters, so when I hand tighten them now I only give it the slightest nip.
I wasn't convinced after the first change but now its sorted I definitely prefer it to the original set up. Quick, clean and easy enough to pre fill the filter without getting it down your sleeve when you refit it.
Jamessigpic Stag Haulage, Flookburgh
Originally posted by Mrs hoskins View PostThanks chaps, I'm just gonna revisit the 70s , and remind myself how hard it was changing the canister type ( admittedly on a mini) ......before I decide whether I splash out on the conversion. On my mileage , I'm only gonna be doing this about every two years , just long enough to forget the pain
I've still got the standard set up - it's a bit of a pain but no major problem to do once or twice a year.
Originally posted by Rod1883 View PostI would recommend that you change the oil at least annually, whatever the mileage you are doing, otherwise the contaminants that build up in the oil will cause corrosion.
Also I find that a good wide pair of water pump pliers are actually handier than a filter strap when it comes to spin on filters!!!
Originally posted by tractorjames View PostI heard as rumour that o ring leakage is often due to the bolt in the middle of the adaptor unscrewing from the block when the filter is changed. The first time I changed the filter the housing was indeed wanting to unscrew. To prevent this I put a smear of flange sealant on each side of the o ring (hylomar non setting type stuff) and loctited the central retaining bolt. I also tightened it a bit tighter than it said on the instructions and haven't had a problem since.
James
Originally posted by 5chaiaday View PostNot sure if I'm being dumb but what is the advantage of swapping to spin on filters? Original filters seem to have good availability and changing is not a taxing job at all. Just seems you're introducing more leak opportunities for little gain.
But maybe I'm missing something?
Ed.
I changed mine for a spin-on type simply because that's what I used to do with my PIs - but on the straight six block the standard filter was set up at an angle and would drain itself into the sump between runs meaning a measurable period of no oil pressure before the filter filled again. AFAICS this doesn't happen with the Stag block.
RichardRichard
I don't know where the bypass valve is in the original filter bowl but I don't recall anything in the filter head that would allow the oil directly back into the engine so I assume it passes over the outside of the element to return to the engine. And as has been said you can fit a larger range of filters and IMO with better filtering properties. For me its one of those mods that takes advantage of progress. Moving on from gauze filters to replaceable elements to throw away filters as used in moderns.
